Got my new setup today which consists of -
E6300
DS3
2Gb Crucial 10th Anniversary
Artic Cooler 7 Pro (may replace with Tuniq Tower - will have to leave case side off though)
Very impressed with this setup so far, priming at 3.4Ghz and no errors so far!! (1/2hr)
However, I noticed the northbridge HS gets very hot, so hot that you can't touch it! Is it safe running it this hot? I've put a 80mm fan blowing over it as temporary measure. Would it be worth getting a 40mm chipset cooler?
Also, finding the Artic Cooler great so far, 58c underload at the moment at 3.4ghz and 1.4v - this is with the side of the case off though, rises by over 5c with it on!! It's a CM101 so airflow isn't the best.
E6300
DS3
