Ds3 prob can u help
22 Nov 2004
Kent
hi
i have the gigabyte ds3
in the pc health status menu it says DDR18V fail
does any one no what this is, i have tryed 2 psu's and it still stays
thanks gavindo
What are you running your Vdimm at? If it is +.3v or over then the it will show fail. It is not a problem its just an indication that you are running your ram out of spec.
