i recently put together a ds3 motherboard with a Core 2 duo e6300 cpu, using geil 1gb (2x512) pc6400 800mhz ultra low latency ram.
I get into the bios no problem, and ive set the memories voltage etc correctly. When my windows xp cd boots for installation it loads the drivers etc but then i get a bsod after it says that its starting windows.
I have used the windows cd on other installs so im sure its not that, to me its either the ram or the motherboard at fault but i really am stumped. Hoping one of you handsome chaps may be able to show some light on the subject.
