Trying to overclock my system but having a bit of trouble. Spec is as follows:
E2180 (stock cooler for now)
Gigabyte DS3-R (v2.1) F10 bios
4x1gb OCZ Vista
8800GT
bios settings:
Ram on auto (5-5-5-15)
Disabled C1E, TM2, EIST
Performance enhance disabled
System multiplier x 2
V.Dimm to +0.3v
MCH to +0.1v
FSB to +0.1v
Vcore tried from 1.35v-1.5v
Tried 8 x 360 to get 2.88ghz and that's the highest it will go before bsod. Tried the same with x10 multi and go the same result.
I was originally on F9 Bios but upgraded to F10 to see if that would help. It didn't
. I want to get this to 3.2ghz minimum really as from everything I have read it should be capable of this!
things to try? Try an older bios revision? Take out 2 sticks and clock again? What settings should a try change? Thanks for the help.
4x1gb OCZ Vista
8800GT
bios settings:
V.Dimm to +0.3v
MCH to +0.1v
FSB to +0.1v
. I want to get this to 3.2ghz minimum really as from everything I have read it should be capable of this! things to try? Try an older bios revision? Take out 2 sticks and clock again? What settings should a try change? Thanks for the help.
