Just built my new system and overclocked to 3.2mhz using the guide for the ds3 thread on the motherboard section and followed it to the word.
I am now running orthos and would like to know if this is stable should I go on or keep it at this clock and take back the cpu voltage to as low as possible currently 1.45v as per the guide my ram is crucial ballistix 6400 and is currently running at 800mhz at 0.3v over the ds3 stock values i believe that 2.1 but ram is rated to 2.2.
im sorta new to all this so not to sure about the voltages temps after 20 mins on both core fluctuate between 47 and 50 idel was around 33
some advice guys if you would to this noob thanks
