DS3P Issues
I have the same board with a 2GB kit of the same ram. You need to call up the bios screen and press Ctrl+F1. Go down to MB Intelligent Tweaker and change the timings to 4-4-4-12 and the voltage to +0.3 (it will turn red but this stuff needs 2.1v). It defaults to 1.8v and 5-5-5-15 otherwise.
Pinky red then. :D
It will only run at your cpu's stock fsb unless you overclock or raise the memory multiplier. What cpu do you have?
E6300 at 300x7 makin it run at 2.1 i can go much higher but it was bein a bit weird and crashed a couple times so i lowered it but its running fine as i found a thread on here the other day which made it a damn sight more stable ive got my memory runnin at 450now by using the easytune app
yeah just edit them press save and go and then u reboot and ** done if it works it boots if not the mobo resets back to stock bios lol
EDIT
well ive got my CPU oc'd to 2.8gig which brought the memory up to 400mhz which is where i think it should be it just confuses me why cpuz reads it as PC2-5300 instead of PC2-6400 which is is i did read sometime back that geil did make a bad batch which was messed up but i cant RMA it as i got it off the bay as it was a bargain prolly cause it was one of the dodgy batch lol
