DS4 and Graphic Card Water Block Problems
27 Jan 2003
Chesterfield, UK
Greetings,
Clearance is a major problem on a DS4. The Northbridge Cooler gives about 10mm clearance. I had to cut the bolt down and remove the spring on my maze 4 G Block. Just something to think about if your under water
The Asgard said:
Greetings,
I'm water cooling my DS4 with no problems
Stelly
Is the noiseless heatsink on the Ds4 a big problem for compatibility? I'm now wondering if the Zalman 9500 that I ordered is going to fit. Any ideas if it will? How high are the heatsinks around the socket?
