ds4+e6400 what settings
Permabanned
1 Dec 2005
i have this i like to clock it abit i have the memory timeings at 4-4-4-12
Corsair 1GB DDR2 XMS2-5400C4
just tell me what settings to put in the bios and i will run prime see how it goes thnx
Memory frequency is somethink like 800mhz its blanked out how do i change it
cpu-z says Memory frequency 333mhz
probably but you will be overclocking the RAM if you only have the 5400. This ram is clocked higher than yours would be @ 3GHz though so you probably won't have a problem.
