hello, im at the edge of buying a new rig, however im debating weather or not to buy a creative sound card to add to the spec, is it worth getting a sound card or is the onboard sound quality from the ds4 good enough?
i know the signal to noise ratio of the creative x-fi extreme music is 109dB, which is pretty good (anythign over 100dB is considered good) so what is the snr of the ds4 outputs? i cant find anything on the gigbyte website, which is odd.
I also realise that depending on the speakers and amps performance this will be irrelevent, however i would like to know
