DS4 - What Memory Slots To Use?
29 Sep 2004
Wilt of the Shire
I've currently got my Geil PC6400 memory in slots 1 & 3 but can't get them to run at 800 mhz. Will they work ok if I put them in slots 2 & 4 instead? If not, I may have to RMA them.
What do you mean you can,t get them to run at 800?can you explain.Have you used the mem divider on the board set it to 2: which is 1:1..
I've somehow managed to get it working at 800 mhz now! Only did the same as I did before but this time it worked. By default the board runs the memory at 667 mhz so you have to change the multiplier to 3 to get the 800 mhz. However, the problem I originally had was when I changed the timings manually. Bit weird but it's all working now - fingers crossed.
