DSLR Strap
19 Oct 2002
Pembrokeshire
Can someone recommend me a good DSLR strap? I remember seeing one mentioned here a while back but I can't find it.
Basically I always used a Black Rapid and that had an connector so I could keep my Manfrotto tripod head mount attached to the camera and the strap attached to that. However after moving to an Arca Swiss ball head I could no longer used that option.
I remember seeing a neoprene strap that acted like a normal strap but disconnected quickly from either side of the camera, I'm having no luck finding that so open to any suggestions please for a good comfortable strap.
Mine is the "OP/TECH Pro Loop Strap" which has the thicker neop cushioning. I then added the "OP/TECH Slingstrap Adapter Connectors" so i have both a traditional round the neck option and the more preferred sling.
I think it may have been the Optech that I was thinking of however the Peak Design looks pretty good, I'm not sure if it would be that comfortable though as it looks pretty thin.
Thanks, decent price to, thought they would be a lot more.
