DSUB 9?? Help!!
30 Jul 2011
I brought a new motherboard and it doesnt have a VGA/DVI slot. It only has a D-SUB 9 slot? I need to connect it to my VGA monitor!
Motherboard: MSI 870-c45
I remember you dude! Like long ago, my old account was 'nVuzion' and I said I blew up my PC. I fixed it now! :D
And yeah, Ive improved with pcs dramatically, anywho, Im using an old 32mb graphics adapter now.
So you got a old pci graphics card with the old Dsub/VGA output?
Whats the monitor got as connections?
Oh so you want to upgrade the graphics card to something with some poke?
Budget?
What PSU do you have? make and model?
And the monitor has a VGA/Dsub only input?
Yeah, only those two. Erm budget £400 - £669 (max - not likely)
I was thinking gtx 570 + Antec true power new 650w?
For Call of duty 4 - Max - 250fps constant?
Stulin: AMD Athlon II X3 425 - Im able to unlock it to an AMD Phenom II X4 B25 (But it freezes after a while, Stock cooling and a extra value 450w psu! :P)
Surveyor: I know mines a 60Hz monitor but for CoD4 You need 250FPS to do certain jumps and such.. (:
Not a bad CPU then, things are looking up:)
Well as you can see from my link, a GTX570 can do over 250fps at low'ish resolution but backed up with a stronger CPU.
You have 4GB of RAM?
Link please mate :)
And do you have an idea of why the pc freezes after I unlock my CPU?
Also on my motherboard there is two overclocking switches, when I turn em on the pc doesnt show anything on monitor, only after i turn it off it does.
http://www.techpowerup.com/reviews/ASUS/GeForce_GTX_570/8.html
Test system
Test System - VGA Rev. 12
CPU: Intel Core i7 920 @ 3.8 GHz
(Bloomfield, 8192 KB Cache)
Motherboard: Gigabyte X58 Extreme
Intel X58 & ICH10R
Memory: 3x 2048 MB Mushkin Redline XP3-12800 DDR3
@ 1520 MHz 8-7-7-16
Harddisk: WD Caviar Black 6401AALS 640 GB
Power Supply: akasa 1200W
Software: Windows 7 64-bit
As for the unlocking problem, could be as simple as the disabled core actually being faulty so didnt make the quad core grade and was instead given tri-core status from AMD and sold as such. Core unlocking is not guaranteed at all.
No AA and No AF means the graphics card can take it easier, see how you get on, but a GTX570 should have no issues with the settings cranked up.
