26 May 2014 at 15:33 #1 spluff spluff Soldato Joined 19 Oct 2002 Posts 2,599 Hiya, I need to convert some mkv files from DTS to Dolby Digital5.1 Whats the best free software to do this which wont affect the quality? Thanks
26 May 2014 at 16:32 #2 jh30uk jh30uk Permabanned Joined 19 Feb 2014 Posts 3,832 Location To Freemake software: http://www.freemake.com/ FREE but uncheck the added crapware.
27 May 2014 at 15:18 #3 spluff spluff Soldato OP Joined 19 Oct 2002 Posts 2,599 Is there anything else I don't like the idea of the possibility of crapware
27 May 2014 at 15:28 #4 jh30uk jh30uk Permabanned Joined 19 Feb 2014 Posts 3,832 Location To Uncheck it, its optional and keeps it FREE and your only feedback in 24 hours.
27 May 2014 at 15:32 #5 spluff spluff Soldato OP Joined 19 Oct 2002 Posts 2,599 oh ok I know some programs will still and try to install the freeware if I uncheck and its fine then ill do it
28 May 2014 at 19:24 #6 Blackjack Davy Blackjack Davy Soldato Joined 16 Aug 2009 Posts 8,280 Eac3to, use the older GUI
