I’m building a new PC and I need to update my screens. These dual sammy 172xs have served me well, but its time for a resolution and screen size jump.
I want to keep a dual monitor set up so I have been mostly looking at Dells range… to tell the truth mainly because of the looks. The entire range is consistent and they stack side by side very well.
I don’t think a 20”/22” wide will offer a big enough resolution jump from the 17” 5:4 screens, so I have been looking at the 20” 4:3 screens – or more precisely the 2007FP.
(Also thought about a 2408WFP with a 2007FP secondary, but I have been off put by the reports of quite bad lag. Noticeable lag on the desktop just isn’t acceptable; I don’t care how good the picture is. I’m not ruling it out as a possible future upgrade. Maybe when the price drops and a later rev comes out or maybe a 2409 that fixes everything
So anyway, dual 2007FPs:
I intend to play games etc, do a bit of photo editing, general desktop use and I would also like to run my PS3 through one of the screens. I currently use a HD Projector with my home consoles which is perfect for games / films etc so I am not interested in using the PC screen as a primary console monitor. More the fact that I’ll probably pick up PlayTV, and I don’t particularly want to watch TV in the dark with PJ on etc etc and the fact I don’t want to turn the PJ on and off just to catch a 30 min TV show or just to check what the PS3 is recording etc. I would much rather have the HDMI connection that is running to the PJ split and have a signal connected to one of the PC screens so I could just change the source and check up on things on there. Or maybe watch a little TV through it while PC gaming etc
So a couple of questions:
With the PS3 running through the DVI port, how good is the monitors VGA port for PC use??
How well does the monitor handle a 720p PS3 signal?
Does it support HDCP? I’m assuming it will display a 1:1 720p picture with black bars top and bottom and not stretch the image?? (HDCP shouldn’t be an issue as I’m not going to watch bluerays through it anyway…)
The 2007FP Has gone through the dell panel lottery… for my use, which is general hobby level photo editing and fairly relaxed gaming (WoW, various FPS etc – no Clan Haxx0rz DM type stuff), which type of panel would be best?
The S-IPS or the S-PVA ?
As far as I understand it, S-IPS will over a more natural colour range and wider viewing angle (not that the viewing angle matters to me) but may suffer from lag or will at least be slower than the S-PVA panel which may offer better gaming performance and black levels??? Or is the difference really not at all noticeable unless you perform lab tests on the damn things…?
Thanks. Hopefully someone can confirm some details and make my monitor choice a little easier
)So anyway, dual 2007FPs:
