Dual Band AirPort Extreme - 5GHz problems?
16 Aug 2004
New Jersey, USA
I just wondered if anybody else here has the latest model simultaneous dual band AirPort Extreme?
We've had one for a few weeks and I just can't get the 5GHz network to work - it appears in the network list as a separate network but nothing can connect to it. All the Macs say 'Connection Timeout' after putting the WPA key in.
The 2.4GHz band works fine, but it's totally pointless having the dual band capability if it doesn't work correctly!
I've tried everything, even setting it up from scratch twice and altering every different option under the sun, but it just will not work.
Apple Discussions is full of posts about it but no real solutions. I think this is the first Apple product I've bought for a long time that doesn't 'just work' :(.
Is it a late 2009 one though? Do they run firmware 7.5 (not available for download)?
They changed wireless chipsets when they revised them a few months ago which seems to have caused the problem...
Ah, so yours have the old chipset which works fine.
The problem is contained to the post October 2009 ones - and you can't downgrade the firmware as 7.4.2 doesn't work on the new chipset :(
Full reset been tried?
If that doesn't work applecare time!
AppleCare are telling people that they are aware of it and that the next firmware update will fix it... which is great, but people were being told that in mid-October and it's now the end of January 2010...
