Dual Boot, 2 x XP with same License?
18 Oct 2002
Sandwich, Kent
Is there any restriction on the number of times you can have XP installed on one computer.
For example, having two boot partitions, both XP with the same license.
in which case
take a ghost of the image. I have a clone of my hard drive (74gb Raptor) on my File HD (250gb)
if ever anything goes **** up i can just restore the disk file for file how it was. Best thing about it, its done using windows own total PC backup built into vista so 100 % legal
but you can achieve the same result using Acronis True Image / Norton Ghost or similar.
oh and for what its worth, the dual boot as a recovery tool would be useless, as none of your changed would be mirrored. You'd might as well just keep a backup of your files and reformat.
