Dual Boot advice
TC1
TC1
Permabanned
10 Jan 2007
I have Vista on one Hard Drive. I have a spare hard drive that i want to put XP on. How do i get to choose which one i boot to when the PC loads up? I have not installed XP yet. Thanks
williamw11 said:
You should be presented with two options at boot up and you select whichever you want. :)
it's not as simple as that. you would do if you installed xp first and then vista afterwards. but the OP has vista installed, and wants to add xp.... :)
i saw this tutorial in another thread the other day. not sure if it works though.... :p
http://apcmag.com/5485/dualbooting_vista_and_xp
So, how do i install XP on a 2nd hard drive, leave vista on the existing HD but when the PC boots have the option to boot to either? The Tutorial above is for putting XP on the same HD. Not what i am after.
