Dual boot - auto selecting XP?
7 Feb 2004
At the moment my computer defaults to Vista as the choice if i leave it to boot up on its own.
Is there a way of making sure it uses XP as the first choice so I dont have to watch my computer start up?
Thanks.
Merry Christmas all! :D
Run -> msconfig -> boot tab -> should be a list of OS, Vista will have "default OS" at the end.. should be a way of setting XP to default.
I think :)
I just had a look in msconfig to find that out, but I only have Vista installed so dunno... :)
That screen? Need to be in Vista. Then select the XP OS I guess you must have in the lest and click the Set as default button.
Is how I imagine you do it :)
