Right now i have w7 booting from hdd 1 its a mess, unactivated and was never intended to be permanent
i want to install w7 again properly on HDD 2 clean tidly and activate
until the new OS is installed completely i want to dual boot win 7 from 2 separate drives with the intention of deleting the one i use now once the second is setup
i want a MBR to be located on both drives so i can format the HDD 1 installation without loosing the ability to boot from HDD 2
ive read that to do this i have to physically detach HDD 1 from the motherboard otherwise the 2nd install will use the MBR from the first install on HDD 1
help needed!!
on another forum someone has said i need a boot manager, i hope i odnt as i will only have one OS eventually
help needed!!
owww ... I have done this ..
