- 30 Aug 2008
Hi Guys
i have 2 sata 500gb drives 1 has xp pro64 and i want to load Vista Ultimate64 on the other, when i tried it took ages to go through the motions nearly 12hours in the end when i just let in run it failed installation, i was running 8gig on a asus striker 2 formula, latest bios updated with quad 2.83. bfg 280gtx
so i took out 4 gig as 8 did give me a issue with xp.
It was very slow even with 4 gig about 3 hours and all it reached was 44%
tried re-formating the sata drive through xp , tried booting from cd, it does start but takes so long it falls down after hours upon hours of waiting for it to install, i do not want to update as i want to dual boot between xp and vista, but im thinking i should have stayed with 32bit, never had this bother before with loading os.
Thanks for any help you can give
