Dual Boot
6 Apr 2010
Cambridgeshire
Hi All
Its been a while since I have played with any dual booting systems and wanted to really know the best way of doing it. Treat me like I know nothing about it. :P
Basically I have an old 1Tb HDD and I thought I would give Ubuntu a muck about with on it. I want to attach it up in my PC and when I boot up the PC to have an option to boot either from that drive of my windows drive. I will not be sharing any drives though, so for example when I am in Windows the Ubuntu 1Tb drive is not see and vice versa.
So yea...is there an obvious 'slap my self round the face' easy way of going about this?
Thanks
EDIT: I dont know if it makes any difference to what you will tell me, but currently I have a F3 500gb with 2 partions (windows and games) and a 2Tb drive (uni and media).
I guess I am wanting:
Boot into Windows: 500gb and 2tb drive seen
Boot into Ubuntu: 1Tb seen
Whichever OS you choose they will see the other HDDs installed on the computer. There is no way around that short of either removing the file/unmounting in Windows/Ubuntu or physically unplugging the drives.
I dunno why you are worried about them seeing the other partitions/drives. Unless you do something stupid they will not interfere with each other.
Ah ok then.
I was hoping there would be a way round it just to make life easier.
So would I similar mount the ISO, install to the other drive and on next boot my computer will ask me to choose or something?
