Windows Vista is installed
If you completly reformatted your hard drive and wiped out XP when you installed Vista, your setup is going to be a little more complicated. Follow these steps:
Boot up your computer with a Windows XP install CD and install Windows XP to a different partition or physical drive than where Vista is installed. When the setup is finished, your computer will automatically boot into Windows XP. Don’t worry, Windows Vista is still on your computer if you correctly installed XP to a different partition or physical drive.
When you installed XP, the Vista Boot Manager was replaced by the Windows XP boot components. The Vista Boot Manager needs to be fixed by using the Windows Vista install DVD. Boot your computer to the Windows Vista install DVD , click Next on the regional settings screen and then click on Repair your computer in the lower left of the window. Select your Windows Vista install and then run the Startup Repair. This will fix the Windows Boot Manager and Vista will once again startup automatically.
Now we need to add an entry to the Windows Boot Manger for Windows XP. This is done through Windows Vista. When you are back in Vista, open an administrative level command prompt window and run these commands:
bcdedit /create {ntldr} /d "Windows XP"
bcdedit /set {ntldr} device boot
bcdedit /set {ntldr} path \ntldr
bcdedit /displayorder {ntldr} /addlast
Reboot your computer and test out the new boot menu.
Dual boot has now been configured on your computer. You will be able to enjoy the enhancements of Windows Vista without giving up the ability to run older applications that require Windows XP.
