Dual Booting Bluetooth Keyboard Problems
16 Jan 2006
Yorkshire
Does anyone have a solution as to how to get a bluetooth keyboard to work in both XP and Vista without having to re-pair the device with the PC every time i switch between OS?
Currently I go into bluetooth and add a device - at which point I have to press the "make/break connection" button on the keyboard or the PC does not see it. I have tried using a generated passkey, my own passkey and even no passkey. Then I boot into the other OS and the keyboard no longer works and the PC doesn't see it. The only way I can get it to connect is to press the"make/break connection" button on the keyboard again - which means it no longer works in the other OS!
I am dgoing round in circles. Is there any way to fix this so it works in BOTH OS without having to re-pair every time?
Any help would be great. Thanks.
