Dual booting XP and Vista
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi
How do I setup dual booting
I have a IDE HDD ( D: )
and a SATA HDD ( C: )
My XP setup is installed on my D:
I wanna install Vista on my C:
YOu may need a boot disk manager but that depends what Mbo you have ,
Install it on the disk drive you require ,,,disconnect the other cable connect up the one you want to install Vista on , insatll Vista and connect up the other HDD.
When you boot up your machine hit either F8 or Escape and see if a boot menu appears ?
Viloa , Vista or XP
With XP already installed, I just connected a new SATA drive, formated and then installed Vista - Vista boot menu was automatically installed (but you must have XP already installed - it doesn't work if you install Vista first and then XP IIRC)
Viloa , Vista or XP
u shouldn't unplug the xp drive because vista needs to see the xp drive so it can make a boot menu...
Yep thats its it, just how i have installed it on my machine :D
yes, boot order is CD first, then HDD.. it comes up with the "do u want to boot from CD option...press any key" so i press a key, and it just goes sstraight into loading XP
Got a usb keyboard, per chance? Sounds like the keyboard isn't working during the boot process.
