Just reading the sticky and is says
'You should install each operating system on a separate logical drive. If you install multiple operating systems on a single drive, you may experience problems when you attempt to run those operating systems.'
But its dated 2002, I was hoping to dual boot with win xp pro and vista can I use the same HDD? I was going to create three partitions 1 for xp 1 for vista and 1 for data.
Advice on this would be great
