Hi,
Ive downloaded windows 7 and ive already got windows xp installed. The partition that im planning on installing windows 7 has got all the programs/applications that use in windows xp. During the installation it said that it would move all the files on that partition to a folder called 'windows.old'. If it does this would i still be able to use my programs when i boot up in xp (since i presume all of the directories will have changed) without having to reinstall or re-locate all the .exe's
also if i decide that i want to remove windows 7 how would i go about doing it? is it just a case of loading up xp and deleting the windows folder on the partition that i installed windows 7 on?
