Hi guys. Recently bought a new computer and the past couple of days I've been getting BSODs as soon as Windows started to load. I tried everything I could think of (format drives, re-install Windows etc) and nothing worked until I took out one of the RAM sticks. Now it starts perfectly every time and it seems to be ok. I've swapped the sticks around to see if one of them was faulty but they both work fine (independently).
As soon as I put both sticks back in though the BSOD reappears so I'm certain it's an issue with dual channel.
Specs are:
i5 2500k
ASRock Z68 Extreme4
8GB Corsair XMS3 (2x4gb)
GTX 570
Windows 7 64-bit Home Premium
Nothing is overclocked, everything is at stock. Is there a setting in the BIOS I need to change? I poked around but to be honest I didn't have a clue what I was supposed to be looking for.
Thanks for the help.
Specs are:
i5 2500k
ASRock Z68 Extreme4
GTX 570
