27 Jun 2010 at 14:23 #1 Cookeh Cookeh Soldato Joined 21 Jan 2010 Posts 8,442 Location Ceredigion Hi, As per title really, is there much of a performance gain of using dual channel over single? Thanks
27 Jun 2010 at 14:28 #2 arknor arknor Caporegime Joined 22 Nov 2005 Posts 46,853 depends on your ram it never used to be back in the old days. http://www.tomshardware.com/reviews/PARALLEL-PROCESSING,1705-11.html but with the faster ram of today it might not have the bandwidth needed.
27 Jun 2010 at 14:30 #3 Cookeh Cookeh Soldato OP Joined 21 Jan 2010 Posts 8,442 Location Ceredigion Ah k, thanks for that. So it seems that while DDR2 is negligible, DDR3 might see a decent boost from it?
27 Jun 2010 at 21:56 #4 mcompute mcompute Permabanned Joined 26 Jun 2010 Posts 77 Technically it's better but i doubt you'll see any effect.
