Ok, just been reading up on oc'ing the CPU and its been said that to run Dual Channel you need to run your two mem sticks in slot 1 & 3, rather than 1 & 2, is that correct?
As you can see i#ve got mine in 1 & 2, should i move the one in 2, to slot 3?
Cheers.
PS: GeiL Value 2GB PC3200 DDR Dual Channel Mem Kit.
Cheers.
. If it says single channel, move the DIMM from 2 to 3 and check again.
