Dual Channel RAM Question
16 Dec 2013
Ok so today i built my friend his first Custom Built PC and we had it all plugged up together and what not i turned it on and it turned on fine and lit up blue (as the fans have blue leds) so everything was fine but when i plugged it into a Monitor (well a 32" tv) it didnt seem to display anything now im just wondering is it because im using 3 Sticks of ram on a dual channel motherboard? Please help..
Specs:
AsRock B75 Pro3-M
Intel i3 2110
Corsair 500w PSU
Sapphire Radeon HD 7770
1TB WDD HDD
AeroCool xStike Case
Kingston Hyper X 6G 1600Mhz DDR3 Module
The only other two problems i could think of would be the ATX 24 Pin connector isnt fully clipped in as for some reason no matter how hard you push it, it just wont clip into place and the other problem may be that i connected the tiny switches from the top of the case to the motherboard the wrong way, im not exactly sure but i hate seeing him depressed as a friend i care if you know what i mean.
