Hi Guys,
I'm just trying to make a final decision on what memory to go for in a new AM3 build. Before I started looking I was thinking of getting 8GB dual-channel but as these kits seem vary rare (and expensive if you can find them) I've decided against it for now.
I now can't decide whether I will be better off getting a 4GB dual-channelkit or getting a 6GB Tri-Channel kit (which obviously will not run at either dual/tri-channel on AM3)
So basically do you think I'm better off having less memory running in dual-channel or going for extra memory but sacrificing dual-channel?
Just after some opinions really, how much of a real-world difference do you think dual-channel makes?
Thanks.
Thanks.
