 - 24 Feb 2007
im ashamed to ask this but sick of wondering.  For optimal performance you should match your fsb and memory speed but when dual channel comes in to play, does this mean you can run both modules at 1/2 the speed and still have the maximum bandwidth?
e.g 1066mhz fsb and 2x533 modules in dual channel - is this optimal?
or is it only optimal if you have 2x1066mhz modules in dual channel for that fsb?
This is my weak spot when it comes to computers please help, some figures for bandwidth would be good for both of those scenarios i suggested if its easy for anyone to work out
) Thus, when nvidia introduced socket A to dual channel ram, doubling theoretica bandwidth to 6.4gb/sec, there was very little difference in performance. the reason was because the cpu's are limited to to the same bandwidth as a single stick of ddr, get it? you cant increase performance by stuffing 6.4gb/sec down a cpu's throat if it can only process 3.2gb/sec.
