dual channel?
Caporegime
20 May 2007
Surrey
hi
I have two 512mb dimms of pc3200 running in ddr. I want to get another gigabyte but still run in dual channle, should i get a 2x512mb kit or a single 1gb dimm?
nope.
in the context of memory dual = two memory controllers. it's perfectly possibly to run dual channel with 3 sticks. 512mb on one controller, 2x256mb on the other. or 1gb/2x512mb
It is also perfectly fine to run 4 sticks of the same size in dual channel, 2 sticks on each.
james.miller said:
nope.
ok so 4x512mb sticks will definately run in dual channel mode then? or do i have to change something in the bios?
Its called Interleaved when 4 sticks are used.
when 2 sticks are in the correct slots then its Dual Channel
james.miller said:
'interleaved' has nothing in common with 'dual channel'! 'interleaved' concerns keeping more than one page of ram open at a time in an over-simplified sort of way.
http://www.georgebreese.com/net/software/readmes/venabler_v015_readme.htm
http://www.realworldtech.com/page.cfm?ArticleID=RWT110401204523&p=3
there's still a lot of misinformation spread concerning memory.
and Jono yep, it'll run. just try to keep the sticks identical if you can, to minimize any possible problems.
I never said that Interleaved had anything to do with dual channel!
what does that mean then? its dual Channel regardless of how many sticks are used. if both memory controllers have ram attached, thats dual channel:)
It certainly should stay in dual channel mode if you use another pair of 512MB DIMMs. Whether it will if you use one 1GB DIMM is down to the memory controller and there's no need to risk it. I have two PCs each with four DDR2 DIMMs and they're both in dual channel mode. I can't tell whether they're interleaved as well but I hope so....
Are you a dumbass ? 2 STICKS is dual channel when in the correct slots.
4 sticks is dual channel as well. 3 sticks = dual channel if the configuration is right. dont try to be a smart arse, fool. it doesnt suit you:rolleyes: you know damn well i was refering to your comment about 4 sticks = interleaving.
