Dual Core AMD cooling
24 Jan 2006
Hi,
Looking for a cooler for my Opteron 165 @ 2.6Ghz as the stock cooler runs at 53C under load with the heating off and the room quite cool.
I am thinking of the Big Typhoon but all the reviews I've read are for overclocked single cores which doesn't give a real performance indicator for an overclocked dual core.
So I'd like to know:
Cooler type including fan
CPU voltage
CPU speed
Temperatures idle and load
Approx room temp
noise
Hopefully this will be usefull to others.
Thanks to all who reply
AD
Si120 and Panaflow FBA12G12L1A 120 x 38mm Fan
Opti 170 @ 2.8 1.35V
2 x Panasonic Panaflo FBA12G12L1A 120 x 38mm case Fans front and back, Akasa amber 120mm on the side, all controlled through a Akasa pro controller
Temps 32 idle 44 both cores @ 100%
Room temp 21C
All fans at 50% just a whoosh of nice cool air.
