Dual core / Dual CPU
6 May 2009
I remember seeing some boards (mainly server ones) that have dual sockets so more than one CPU can be fitted.
What is the advantage of this over single CPUs with dual/quad cores?
Can Dual CPU board take dual/quad core CPUs?
Yes, they can, which means you can have an eight core Xeon or twelve core Opteron system, for example. Memory bandwidth can also be increased by using the memory channels available to each CPU (i.e. NUMA). Another advantage is the increase in maximum memory support. Most dual channel, single socket consumer boards support 16GB at most, whereas a dual channel, dual socket server boards support 32GB+
Why arnt dual channel, duel socket made for home use? Does no home consumer applications or games require them? (yet)
There's the Intel Skulltrail platform from a couple of years ago, which was aimed at "enthusiasts". I suppose the main reason that multiple socket systems are not aimed at home use is the cost. Apart from the Skulltrail and the old AMD XPs that could run in MP mode without modification, most multiple processor systems are workstation/server grade. This means that they use expensive server processors (Xeon/Opteron etc), workstation/server boards with PCI-X slots, onboard SCSI/SAS and other enterprise related things, and typically have specific requirements for ECC/Registered/Fully Buffered RAM. They also typically lack things that consumers/enthusiasts expect, such as onboard sound, SLI/crossfire etc. The manufacturers know that the bulk of these components and systems will be sold to business users, and so they can keep their prices much higher than consumer level kit.
When you consider that most people buy from the perspective of what's "good enough" when it comes to computers, the popularity of cheaper, single socket systems becomes even more logical. I've been using SMP systems since my first dual Athlon MP system back in 2003, but for most people it wasn't until much more recently that they moved away from uniprocessor systems, simply because they were good enough.
There were multi cpu solutions for desktop PCs but they didn't take off.
Look up Intel Skulltrail and AMD 4x4.
