- 28 Nov 2005
Is it harder to overclock than a single core.. or is it just the same
lemonkettaz said:Is it harder to overclock than a single core.. or is it just the same
What cooler is that with? My XP-120 keeps my X2 @ 2.66GHz at between 50 and 55 degrees C after having been loaded with 24 hours of two Prime95 instances - that's with 1.45 volts too. Still, 51 isn't too much to worry about.Phemo said:Not surprising that it kicks out more heat reallyWhat cooler is that with? My XP-120 keeps my X2 @ 2.66GHz at between 50 and 55 degrees C after having been loaded with 24 hours of two Prime95 instances - that's with 1.45 volts too. Still, 51 isn't too much to worry about.
Agent WD40 said:What temps should I be worried about?
SpudMaster said:with my 170, im not having problems with cpu heat (using water) but the PWMIC area on my dfi ultra-d gets hotter n hotter the more i push the cpu. at 2.7ghz with 1.39v it not really a problem but for 2.8ghz it needs 1.48v on the core and the PWMIC is hitting 67-70 degrees. The cpu seems stable till the PWMIC hits these temps
Legless said:When you overclock a dual core system, do you overclock each core seperately, or both at the same time/speed...![]()
Agent WD40 said:both cores at the same time, they are controlled by the same factors![]()
Havana_UK said:X2s are good clockers, however, I have some observations:
1. They don't go as far as the single cores
2. One core is normally better than the other, i.e. one core will be stable at a given speed but the other core needs more volts to get stable
Hav
Ping said:is there a way to tell if 1 core is better the other ?
I have always thought that its better to have a large fan blowing air down onto the CPU and surrounding circuitry, but it seems a lot of people place the cooling emphasis on their CPU alone.IzaLearnin said:I was having a similar issue after changing from the xp120 (which cooled the pwmic area) to the Evo 120 which doesn't! I fixed a low power Papst 120mm fan to blow over both my ram and pwmic heatsinks and used a 4-3 pin connector to use the m/board pwmic fan header and Smartguardian to control the fanspeed according to temperature.
