- 29 Dec 2005
installed an fx60 in my PC, had a fx57 before, ran 3dmark 06 and got less than my single core score, dont think im using both cores, as i cannot acess them on cpu-z and taskmanager, is there something i need to do, to activate them, it isnt a fresh install, just a swap, also on a asus a8r-mvp if it helps, only got 1012 cpu score on 06 which is about the same as a single core.
