- 26 Jan 2005
Hi there need a little help, I am running at stock everything at the moment but when I try and test both cores using SuperPi I can't run to instances of the program.
I set the affinity on both copies of SuperPI open to different cores, when I run the first instance it will run fine but the second instance fails with error
NOT CONVERGENT IN SQR05
Bore cores can complete SuperPI without errors, but only when the other core isn't running a nother instance of SuperPI.
Any ideas???
Any ideas???
