Disclaimer:[Not sure if this should be in "Monitors Thread" but having a go here seeing it seems to be a GFX issue]
System Specs:
CPU: i5 2550k + Akasa AK-CC4008HP01 Venom Voodoo CPU Cooler
Mobo: Gigabyte Z68AP-D3 LGA1155 Intel Z68
Ram: 2 x 4GB G.Skill DDR3 PC3-10666 Ripjaw Series
GFX: GeForce GTX 560 Ti Twin Frozr II - 1 GB GDDR5 - PCI-Express 2.0
HDD: 2TB Seagate Barracuda Green/ 500 GB Random / 16 GB SSD
PSU: Akasa Venom 750w Modular '80 Plus' Power Supply
On my late late GFX (god bless it) , I was able to get dual display (GTX 250) by using one DVI and one VGA cable.
Unfortunately it doesn't seems to work for my current setup so wondering if anyone knows what could have gone wrong?
I have the DVI monitor plugged in and it shows as Display 1 (Main monitor) and I have the VGA monitor plugged in using the DVI to VGA adapter but the second monitor just stays blank and m display setting only picks up one monitor. Both monitors are working fine.
I've tried to restart a couple of times with no success.
Any takers?
System Specs:
Any takers?
. Afterwards, an upgrade to the lastest drivers might be a good move (if you haven't got them already).
