Dual display PCI-E graphics cards
1 Mar 2003
Cotham, Bristol
I'm wanting a cheap and cheerful graphics card that supports dual monitors, I did have Dell create a spec for me that included the below card
http://www.amd.com/uk/Documents/AMD_Radeon_HD_7470-HD_7450_GPU_Feature_Summary.pdf
What I can't work out however is does it support dual monitors? I can see it has VGA, DVI and HDMI but does it support dual monitors? If not could someone point me in the direction of one, nothing fancy.
Yes it does support dual monitor, it says Native support for up to 4 simultaneous displays. What inputs do you have for your monitors ?
