Dual Display, Possible to play games on secondary monitor?
5 Dec 2002
The 80's
Hi Guys,
I currently have 2 monitors running off my PC. A Dell 2407 and An LG W2261VP. I'm running an Nvidia GTX260.
My Dell is my Primary *1 Display and my LG is my 2nd. Is it possible to get games to run on the LG as default?
I can't see a way in Nvidia Control Panel to do this. Is there a way via an secondary piece of software?
Sorry is if this is not in the correct section of the forum.
Thanks
:D
I think with UltraMon you can configure certain programs to run on the second display.
I'm near sure I've done it before with it.
edit: I think you setup a hotkey for switching the primary monitor to the second display.
Not sure if it's what you're after, but you can set the LG as the default monitor (Right click desktop > Screen Resolution > select LG > Make this my Primary Display > OK). You can then drag and drop your taskbar onto the Dell so that still "looks" like your primary display.
Not an option if there's a reason you need the Dell to be the Primary, but if you always want full screen games to play on the LG then this should work for you.
