Dual display problem.
8 Dec 2004
Hampshire
I have an XFX 6950 on a W7 64bit machine.
My main monitor is a 24" DGM effort and I have a 32" Sammy LCD TV to the side.
Try to "extend desktop" through the settings but I keep getting a "Unable to save settings" message.
This seems to a be problem that has arisen since reinstalling W7 recently.
Any ideas how to fix this? Thanks in advance.
Ok solved it. For some reason the top DVI connector would work in extended display mode but the bottom one would not (in conjunction with the HDMI which is connected to the Sammy.
Something to do with VGA outputs. Anyway all sorted now.
