Dual display
17 Dec 2008
Hi guys I have an and hd5700 card with dual dvi ports have tried to connect a second screen on the computer it shows 2 monitors in devices but I cannot get a picture on second monitor I have heard that this card does not support dual screen can anyone confirm this
Thanks
In Windows 7(I assume Vista/8 will be similer), you can right click the background, select screen resolution.
If using two monitors, there should be two monitors to select there there.
To get the two screens working at the same time, simply under the "Multiple Displays" there should be an option to "Extend these displays".
If that doesn't work then I'm not sure what it would be.
