- 13 Mar 2007
- UK
So, I went down for dinner, came back up. Room smelt of smoke, power supply had exploded/burnt out
So I took all my stuff out and sent the case and PSU back.
Meanwhile I'm using an old slow PC.
3 weeks later. I receive the case and power supply back, plug in everything and all the fans work apart from one that shows on the back of the case of the power supply.
In the bios, The Q-FAN was disabled, so I enabled it. Don't know if that helps anything, then I enabled CHA 1 fan, to 800 RPM (this was disabled) and enabled the Cool&Quiet mode.
The fan still didnt work and I had the error CHA 1 fan is too low, so I put it up to 1200RPM and I didn't get the message then it says
"DISK READ ERROR" (the one you get when you need a operating system installed....)
I had recently reformatted my PC and a few days after doing this, the above happened.
Any chance my HDD and motherboard and any other stuff could have been effected when the Power supply burnt out?
Case and power supply: Clicky
Mobo: Asus A8N-E
HDD: Clicky
Anything else you need to know?
Mobo: Asus A8N-E
HDD: Clicky
