Hi guys,
Basically, I have two computers, right next to each other, that I wish to use on the one pair of dual monitors and mouse/keyboard. So basically like a KVM switch, but software.
RDP seemed like the way to go with this, however I have hit a brick wall in that my two monitors are different resolutions, following advice it seemed that SplitView is used for this stuff, though having installed it and further reading through the docs it says that it's best if they're the same height, otherwise you'll get a strip of unused screenspace on the taller.....
Erm.
What.
Surely there's a decent way to basically set up a kvm switch through software. KVM switch would be annoying for a few reasons: expensive, would need to be a dual monitor and dual usb switch, and I've used usb switches before and there's a lag in going from one to the other. Also, I wish to be able to trigger the switch from keyboard/mouse.
Any ideas guys?
Thanks for reading.
Erm.
What.
Any ideas guys?
Thanks for reading.
