Hi,
i have bought a Gigabyte GA-G31M-S2L motherboard with an onboard Intel VGA. I have put in a Radeon 3850 as well.
The idea was to run two monitors off the Radeon and run my case front screen (Zalman HTPC160XT) off the onboard but.....
The intel driver picks reports its disabled a card as it doesnt match, but it disables the onboard and leaves radeons working.
This is with default bios of initialise pci first, if i set it to initialise onboard first, then the radeons dont work.
There must be a way to run both these together?
Tried gigabyte support but links constantly time out.
Regards
Regards
