- 17 Aug 2010
Hey everyone
I recently upgraded my graphics card from an oooold Nvidia 6600GT to a GT 240. Once I installed the GT 240 I decided to try out dual monitors and it worked perfectly. My motherboard supports SLI and after a conversation with a friend I installed my old 6600GT in the second PCI-e slot but didn't switch the motherboard to SLI mode. To my great surprise my PC detected the 6600GT and I successfully had three monitors going at the same time, the two cards obviously aren't working in SLI, it seems like the 6600GT is just an output.
My question is, Is this affecting the clock speed of the GT 240? or affecting the speed in any way? From what I can see it hasn't appeared to have made a difference but I can't be sure :/ Am I correct in thinking that anything outputted from the GT 240 will use the GT 240's memory/speed and anything from the 6600GT will use the 6600GT's? So If I had a program on the screen connected to the 6600GT it would run slower than the programs on the screen connected to the GT 240?
Thanks a lot and sorry if this is an obvious question, I just cant get my head around what's happening!
