- 27 Mar 2004
- Between Realities
Okay just want to check if this sounds about right to you guys.
I have a laptop that can connnect to my neighbours wireless(Legit, not stolen, secured and shared with me, etc) I also have a adsl line of my own.
I also have a desktop computer with 2 network points.
Now, what i want to do is use my laptop to connect to the wireless, then connect the laptop to my desktop PC using a cross over cable. I will then, bridge the connections on the laptop.
This should technically mean my PC then has 2 incoming internet connections, Over 2 seperate LANs yes?
I then plan on running multiple instances of Utorrent and using the advanced settings altering the net.outgoing_ip address on each instance to the LAN Addresses of each network.
Now this is all theory, as I dont have a cross over cable to test it, I just wanted to see if anyone has done anything similar? Or if from reading what I've put they see where I'm coming from, and that this should work?
I hope what I've written is understandable to some
I know another option with the same setup, would be to just use the Laptop to download to a shared folder on my Desktop, But this is more of a fun "I wonder if it would work" Experience, and it would also mean in the future, I could put a wirelesss card in my PC and do the same thing, With just 1 system running.
