Dual LAN
14 Oct 2007
wubalubadubdub
Got a small prob with my board i seem to be missing my 2nd LAN port :(
its not really a bad problem as i dont use it (yet) but was wondering why its not there any more?
You deffo got 2 LAN sockets on your motherboard? So your saying both were detected in windows and now one isn't? Which version of the OcUK IP35 do you have as the -S doesn't have dual lan.
Do you mean the physical port or it in windows?
If windows check the drivers are installed etc, and that it's not disabled in windows.
yes it has 2 and windows detected it but now its gone
i have the OcUK Value IP35 (the £70 one)
EDIT: its not in device manager
Check the bios to make sure its still enabled, and also check device manager to see if its listed in there.
ok dosnt matter now just tryed 'add new hardware' and it was there, was just disabled. its enabled again now and its given me the red X in the taskbar so now i need to disable it again now LOL
