I take it you are referring to blank DVD + or - R D/L media?
I have used Verbatim Datalife Plus (2.4x) Double Layer DVD+R, it uses the MKM 001 dye, successfully on 2 occassions. This media is a bit more expensive, but it will produce a far better burn quality, this media can also be burnt at 4X, even though it is only rated as 2.4X.
I used Nero Burning Rom v 6.6.1.4 to burn the DVD Video Files.
If you intend to play your burnt D/L media in a standalone DVD player attached to a TV, do make sure that it actually supports it, as older DVD players don't, with the result that it won't play, although it will play on your computer.
